Autopilot ECU High Temperature
If a Reactor GHP 20 or Reactor GHP 40 with a Smartpump receives the error message "Autopilot ECU High Temperature", please check the ambient temperature where the Smartpump is located. Operating temperature range should be between 5° - 131° F (-15° - 55 °C ). If the Smartpump location is above or below that range, the Smartpump will need to be moved to a different location or the area needs improved ventilation. If the area where the Smartpump is located falls within the temperature range, there is an issue internally with the ECU and the Smartpump will need to be repaired. Please contact Garmin Product Support for assistance.
