Troubleshooting Bluetooth or Pairing Issues with the Xero S1 and Xero S App
The following FAQ addresses the various connection or pairing issues with the Garmin Xero® S1 trapshooting trainer or Garmin Xero® S app by clearing and resetting both the device and the phone app in a specific way.
Items to Check
- Ensure that the smartphone is connected to the internet via a mobile data plan or Wi-Fi. The Garmin Xero S app requires a connection with the internet to sync new data or pair with a smartphone.
- Ensure Bluetooth is turned on in your phone settings.
- Ensure Phone Setting is On in the Xero S1 trainer:
- Select Settings
- Select Phone
- Select Settings
- Power off, then back on both the smartphone and the Xero S1 trainer.
Additional Troubleshooting
If the above settings are correct, we suggest these troubleshooting steps.
iOS
- Open the phone's Settings menu
- Touch General
- Touch Software Update
Android
The steps below may vary by Android device.
- Touch Download updates manually
- Touch About Phone
- Touch System Updates
The phone should now check for and apply any necessary system updates.
Clear Pairing History on iOS
- Touch Bluetooth
- Touch the info button ("i" icon) next to the paired Garmin Xero S1 device
- Touch “Forget this device”
Clear Pairing History on Android
- Touch Connections
- Touch Bluetooth
- Touch the gear icon next to your listed Garmin Xero S1 device
- On some Android phones, select the name of the listed Garmin Xero S1 device instead
- Touch Forget/Unpair
The Garmin Xero S1 trainer will now be cleared from your phone's pairing history.
iOS
- For steps, refer to Apple Support - Close an app on your iPhone or iPod touch
Android
- Touch Storage
- Touch Other Apps or Apps
- Touch Xero
- Touch Storage
- Touch Clear Cache
The temporary files should now be cleared and the app can be re-opened.
iOS
- Touch and hold the Garmin Xero S app icon
- Touch the X that appears in the corner of the icon
Android
- Touch Apps
- Touch the Garmin Xero S app
- Touch Uninstall
After the app has been uninstalled, it can be re-downloaded from the App Store or Google Play Store on your phone.
- Select
- Select System
- Select Reset
- Select an option:
- Select Settings to reset all settings to default values.
- Select Format Storage to format and erase all user data stored on the device.
- Select Factory Reset to delete all user data and reset all settings to factory default values.
iOS
- From the App Store on your iOS device, install and open the Xero app
- Bring the devices within 10 m (33 ft.) of each other
- On your Xero S1:
- Select Settings
- Select Phone
- Select Add New
- From the Xero app, select the Plus and follow the on-screen instructions.
Android
- On the Xero S1
- Select Settings
- Select Phone
- Select Add New
- Open the Garmin Xero S app on your smartphone
- Sign in with your Garmin Account, or create a new account
Once signed into the app, select the + in the upper right-hand corner of the screen, and follow the on-screen instructions.
