Changing Batteries on Xero X1i
The Xero® X1i crossbow scope uses two AAA lithium batteries. To replace the batteries, view steps in the owner's manual.
When the batteries are replaced, Bolt Profiles, calibrated aim points, and other customized settings will not be reset or erased.
NOTE: The compass should be calibrated after changing the batteries for accurate Xero Locations. For steps to calibrate the compass, see  Calibrate Compass
