Android: GPS Position/Current Location Is Not Correct
If Your GPS Position Is Not Being Displayed Correctly
Make sure that your mobile device has an internal GPS receiver. If it does not have an internal GPS receiver, you will not be able to determine your location outside of Wi-Fi range. If you are using a device with an internal GPS receiver, follow these instructions to resolve your issue:
Android 12 & Higher
  1. Tap device Settings.
  2. Tap Location.
  3. Enable Location.
  4. Tap Google > Tap Use Precise location.
Android 11 & Lower
  2. Tap Location.
  3. Enable Location.
  4. Tap Advanced > Google Location Accuracy
  5. Turn Improve Location Accuracy on.
If you use an older Android version, see Android's Help Center for more details.
If Your Location is Still Inaccurate
If your location is still inaccurate, open your Google Maps app and determine if your location is accurately being reported. If it is not, it is possible there is something wrong with your installation of Android OS and/or the hardware in your device.
If your location is accurate in the Google Maps app, but you are still unable to locate your position properly in the Navionics® app, verify the GPS is enabled within the app. Navionics Boating: Activating the GPS Function to Show Your Location
For additional troubleshooting try downloading the free application GPS Status & Toolbox: https://play.google.com/store/apps/details?id=com.eclipsim.gpsstatus2.
Open GPS Status & Toolbox app and perform the following steps:
  1. Click on the Compass or swipe on the display on the app.
  2. Click on the menu icon at the top left corner of the screen.
  3. Tap on Manage A-GPS state button.
  4. Tap on Reset.
    This will reset the GPS signal of your phone and generate a new satellite fix and could take several minutes to acquire the new fix.
  5. Wait for the action to complete.
Once you have acquired the GPS fix, restart your device and try again to launch the Navionics Boating app.
Contact Product Support if the issue continues.
Related
