Custom Message or Text on Start Up Screen
Many Garmin® outdoor handhelds can display a customized welcome message on the startup splash screen. This can include a small amount of information, including contact information or a personalized message.
Customizing Start Up Text Using a Windows PC
This is the most common method and will work with the majority of outdoor handhelds.
Connect the device to computer with a USB data cable.
Open the Garmin drive (typically found in [My] Computer or This PC).
Open Internal Storage if listed, otherwise skip to the next step.
Open the Garmin folder.
Copy the file named startup.txt to the Desktop.
Open the copied file named startup.txt.
Follow the on-screen instructions and add the desired Start Up Message.
The maximum number of characters for this text is 256
Replace the original startup.txt file in the Garmin folder of the device with the edited copy from the Desktop.
After saving the file, the customized message should display on the device when powering on.
Customizing Start Up Text Using a Mac
NOTE: A Windows computer must be used for the Alpha® 300, Alpha 300i, GPSMAP® 67, GPSMAP 67i, GPSMAP H1, GPSMAP H1i Plus, Montana® 710, Montana 710i, and Montana 760i outdoor devices. These devices use MTP (Media Transfer Protocol) mode, which prevents them from appearing as a separate drive on Mac computers
This is the most common method and will work with the majority of outdoor handhelds:
Open the Garmin drive (typically found on the Desktop of the Mac).
Follow on-screen instructions and add the desired Start Up Message.
The maximum number of characters for this text is 256.
Customizing Start Up Text on Older Outdoor Handhelds
Some older outdoor handhelds, such as the eTrex Vista®, are not recognized as a drive when connected to a computer and will not work with the steps listed above. For older devices, you may have one of the following options available.
Option 1
From the Main Menu, select
or press Enter.
Select Owner Information.
Use the on-screen keypad to enter your welcome message and select OK when finished.
Option 2
From the Main Menu, select Setup.
Select Welcome Message.
