"Insufficient power: The attached cable cannot currently charge your device" Message
When connected to a computer via USB cable, your device may present a message stating "Insufficient power: The attached cable cannot currently charge your device." This behavior is normal: it indicates that while the device is receiving power from the computer, it is not enough to both charge and run the device.
The device will continue to operate off of external power from your computer in this situation, but the battery charge level will not increase.
For additional information on charging your device, see Charging Factors for an Automotive Device.
