Figuring out if the Teleflex Seastar steering cylinder is balanced or unbalanced
If you are unsure if the Teleflex Seastar steering cylinder is balance or unbalanced, it is best to contact Teleflex's hydraulic steering support at (604) 248-3858.
Below is a breakdown of a sample Teleflex Seastar steering cylinder with the part number BA175-7TMB:
  • BA = Balanced (absence of BA means it is unbalanced)
  • 175 = 1.75 inch bore
  • 7 = stroke (in this case it would be a 7 inch stroke)
  • TM = Trunnion Mount (EM = Engine Mount, ATM = Aluminum Body with Trunnion Mount)
  • B = Rod End Ball Joint (C = Rod End Clevis)
