Upgrading a GHP 12 to a Reactor 40 Autopilot System
If a GHP™ 12 is currently on the vessel but needs to upgrade to the Reactor™ 40 autopilot, the following is required:
Replace the GHP™ 12 autopilot CCU with the new Reactor™ 40 autopilot AHRS
Replace the CCU/ECU interconnect cable with the Reactor interconnect cable
Connect the Reactor 40 CCU to NMEA 2000 using the existing drop cable
Connect the Shadow Drive™ sensor (optional)
Connect the buzzer
Leave tach unconnected
Leave yellow wire on GHC™ 20 autopilot controller unconnected
Below are the required parts and part numbers:
GHP Reactor™ 40 autopilot CCU - 010-11052-67
GHP Reactor™ autopilot interconnect cable - 010-11351-40
Replace the GHC™ 10 autopilot controller with a GHC™ 20 autopilot controller or GHC™ 50 autopilot controller. The Reactor 40 is not compatible with the GHC 10 autopilot controller.
Purchase these parts from any Garmin Marine Dealer. Use the Dealer Locator Tool to find a local dealer.
