I am Having Trouble Getting Good AM/FM Reception
There are a number of factors that can cause poor AM/FM reception in a marine environment. One of the most common causes comes from the antenna cable routing. When installing an AM/FM receiver on your vessel, spend extra time to investigate the optimal routing of cables, including any RCA cables. These should ideally be run away from any other cable and/or electric motors, or potential sources of interference. Power cables provide the worst source of interference, and can be in bundles of cables, so you may not realize they are there. AM reception requires a short antenna cable run for optimum reception, which is not that easily achieved on a lot of vessels, especially when using mast style aerials.
Check that you have selected the correct tuner region in the settings menu as the default setting may be incorrect for your location.
