My iPhone 4 has no Audio Output When Connected to the MS-RA200
Due to the release of the iPhone 4 being after the release date of the MS-RA200, the first version of software does not support the iPhone 4. This can be resolved by updating the MS-RA200 software via a USB flash drive. To check the version installed, select 'Menu', then 'Settings', then 'About'. This will display the current version installed. If the version is 10.1573 you will need to update the software. It is a simple operation and the update is available from Fusion directly by contacting us via email at /marine/contact.
