What NMEA 2000 Data does my NRX200 Remote Control Display?
NMEA2000 REPEATER MESSAGES:
127250: Vessel Heading (Magnetic Heading, Correction, Deviation)
128259: Speed Water referenced (Speed Water, Speed Ground)
128267: Water Depth (Depth at transducer, transducer offset)
129025: Position Rapid Update (Latitude, Longitude)
129026: COG & SOG Rapid Update
129029: GNSS Position Data (Date, Time, Latitude, Longitude, Altitude)
130306: Wind Data (Speed, Direction, Reference)
130310: Environmental Parameters (Water Temperature, Outside Ambient Air Temp, Atmospheric pressure)
130311: Environmental Parameters (Deprecated) (Temperature Instance, Humidity Instance, Temp, Humidity, Atmospheric Pressure)
130312: Temperature (Instance, Source, Actual)
130314: Actual Pressure
130577: Direction Data (Course Over Ground, Speed Over Ground, Heading, Speed Through Water)
129284: Navigation Data (ETA)
