Estás viendo un artículo que no está disponible en el idioma seleccionado actualmente. Elige otro a continuación.
Ideal Speed for Garmin Quickdraw Contour Mapping
When recording Quickdraw contours, the vessel's speed plays a role in the quality of recordings. For best results, the recommended rate does not exceed 10 MPH. With Quickdraw Recording set to on, a colored area around the boat's icon will appear on the chart. Called the Area of Influence, it represents the approximate area currently being surveyed. Additionally, turning on Survey Coloring within the Quickdraw settings menu will give a status of the entire area surveyed. Below is a chart describing what the different colors of this area will mean. While any transducer will work with the Garmin chartplotter to record Quickdraw mapping, a Panoptix transducer will provide best-quality recordings.
Circle of Influence
Surveyed Area
Description
Good Survey
  • Normal use
Over Speed Warning
  • Vessel traveling over 10MPH
Over Max Speed Limit
  • Vessel traveling over 20MPH
Bad Survey
  • No depth source / poor bottom reading
  • No GPS fix
Community Data
  • All community data will be colored grey
