Honda Navigation Map Update
Honda vehicles with Garmin Navigation come with 5 years of map updates at no cost. These map updates are available roughly once per calendar year. Starting in 2015, Garmin began providing navigation in select Honda vehicles. We do not provide navigation for all models of Honda vehicles in all countries after 2015. On our website, you may see a Honda vehicle listed that does not use Garmin navigation in your country or region.
Contact your local Honda dealership for additional information on how to update if you are unsure if your vehicle has Garmin navigation.
NOTE: You cannot use the same map download for multiple Honda navigation systems. Doing this will result in a locked navigation device.
If Your Vehicle is NOT Listed Below - Click Here for Map Update Instructions:
The following is needed to perform the map update:
- 16 GB USB Drive Only
- The Honda Navigation System update requires a 16GB USB flash drive. Using a USB flash drive smaller or larger than 16GB can cause the map update process to be unsuccessful. The following error message may display: "There is not enough space on the device to install the map update from USB storage device."
- Using the Same USB Flash Drive for the Honda Map Update
- High-speed Internet connection
- Up to 4 hours of time (Computer and Vehicle). The map download time varies based on Internet connection speed and map region.
- The map installation will take up to one hour in the vehicle but may vary based on the map region being installed.
- During this update, your Honda navigation system must not be turned off. Therefore, the engine must be running while the vehicle is parked outside or in a well-ventilated area. Before getting started, familiarize yourself with and follow all applicable laws in your area. Please contact your dealer with any questions or concerns.
On the Computer
1. Format your USB drive to FAT32
- NOTE: Steps 1 and 9 (using Garmin Express) must be done within 24 hours of each other when performing the map update. The update process will need to be restarted from the beginning if they are not completed within 24 hours.
2. Take the USB drive to your vehicle
In your Vehicle
The following steps are required in order to imprint a unique ID to the flash drive.
3. With the vehicle turned off, plug the 16 GB USB drive into the vehicle's USB port
- For Honda Pilot 2016 - Use the USB port inside the center console
- For Honda Accord 2016 and Honda Accord 2017 - Use the front USB port under your audio display
- All other Honda vehicles - Any USB port in the vehicle can be used
4. Turn on the vehicle and Select Settings on the Navigation Home Screen
- Select the View Map Screen and then Menu Button (3 dots) if Settings does not display on the Navigation Home Screen
5. Select Device
6. Select Update Map
7. Select OK
8. Select OK and wait 60 seconds before removing the USB drive from the USB port
- If you do not see this message, verify the USB drive is 16GB and is formatted to FAT32. Formatting a USB Drive for a Honda Navigation System
9. Remove the USB drive from your vehicle and take the USB drive back to your computer
On your Computer
10. Plug the USB drive into your computer
11. Open Garmin Express
- See How Do I Install Garmin Express? for instructions.
12. Select Add a Device
- If you've previously added your device to Garmin Express, select on your device and skip to step 15.
- The green dot means Garmin Express recognizes the device.
13. Select Add Device
14. Select Next
- If desired, enter your email address to register the device and receive map update notifications
15. Select Next
- If desired, enter a nickname for your vehicle
16. Select Install
- Information about the available update can be found by clicking View Details
- NOTE: For 2015 and 2016 Honda Vehicles: If following the instructions below doesn't offer a map update, contact Product Support
17. Select Accept after reading the terms and conditions
18. Select Continue after reading the important notes
- Garmin Express will now display Preparing Device for Map Update and then Garmin Express is copying the map update files on to the USB drive
19. Safely remove the USB drive from the computer once the update process is completed and take the USB drive back to your vehicle
In your Vehicle
20. Turn on the vehicle
- The engine must be running while the vehicle is parked outside or in a well-ventilated area. Before getting started, familiarize yourself with and follow all applicable laws in your area.
21. Plug the USB drive into the same USB port used earlier in your vehicle
22. Select Settings on the Navigation Home Screen
23. Select Device
24. Select Update Map
25. Select Yes to continue
26. The screen will display Installing the updated map
27. Select OK after Update Successful message
28. Remove the USB drive from the USB port
To verify the maps were successfully installed:
In your Vehicle
1. Select Settings on the Where To? screen
2. Select Map & Vehicle
3. Select myMaps
The map region and version will display on the screen.
nulo
Honda Accord - 2018 and Newer - Click Here for Map Update Instructions:
On the Computer:
In your Vehicle:
- Any USB port in the vehicle can be used.
4. Turn on the vehicle and Select the Menu Button (3 dots) on the map screen
5. Select Settings
6. Select Map and Vehicle
7. Scroll down and select Map Updates
8. Select Start Update Process
9. Select OK and wait 60 seconds before removing the USB drive from the USB port
10. Remove the USB drive from the USB port in your vehicle and take it back to your computer
On the Computer:
11. Plug the USB drive into your computer
12. Open Garmin Express
13. Select Add a Device
- If you've previously added your device to Garmin Express, select on your device and skip to step 16.
14. Select Add a Device
15. Select Next
- If desired, enter your email address to register the device and receive map update notifications.
16. Select Next
17. Select Install
18. Select Accept after reading the terms and conditions
19. Select Continue after reading the important notes
20. Safely remove the USB drive from the computer once the update process is completed and take the USB drive to your vehicle
In your Vehicle:
21. Turn on the vehicle
22. Plug the USB drive into the same USB port used earlier in your vehicle
23. Select the Menu Button (3 dots) on the map screen
24. Select Settings
25. Select Map and Vehicle
26. Scroll down and select Map Updates
27. Select Start Update Process
28. Follow the on-screen instructions to complete the map update
In your Vehicle
1. Select the Menu button (3 dots) on the map screen
2. Select Settings
3. Select Map and Vehicle
4. Select myMaps
nulo
Honda Odyssey - 2018 and Newer - Click Here for Map Update Instructions:
On the Computer:
In your Vehicle:
- 2018, 2019, and 2020 vehicles - Any USB port in the vehicle can be used.
- 2021 vehicles - The USB port in the front console must be used
5. Select Settings
10. Remove the USB drive from the USB port in your vehicle and take the USB drive back to your computer
On the Computer:
15. Select Next
16. Select Next
17. Select Install
20. Safely remove the USB drive from the computer once the update process is completed and take the USB drive back to your vehicle
In your Vehicle:
24. Select Settings
In your Vehicle:
2. Select Settings
4. Select myMaps
nulo
Honda Insight - 2019 and Newer - Click Here for Map Update Instructions:
On the Computer:
In your Vehicle:
5. Select Settings
On the Computer:
15. Select Next
16. Select Next
17. Select Install
In your Vehicle:
24. Select Settings
In your Vehicle:
2. Select Settings
4. Select myMaps
nulo
Honda Passport - 2019 and Newer - Click Here for Map Update Instructions:
On the Computer:
In your Vehicle:
- 2019 and 2020 vehicles - Any USB port in the vehicle can be used.
- 2021 vehicles - The USB port in the front console must be used.
5. Select Settings
On the Computer:
15. Select Next
16. Select Next
17. Select Install
20. Safely remove the USB drive from the computer once the update process is completed and take the USB drive back to your computer
In your Vehicle:
24. Select Settings
In your Vehicle:
2. Select Settings
4. Select myMaps
nulo
Honda Pilot - 2019 and Newer - Click Here for Map Update Instructions:
On the Computer:
In your Vehicle:
5. Select Settings
On the Computer:
15. Select Next
16. Select Next
17. Select Install
In your Vehicle:
24. Select Settings
In your Vehicle:
2. Select Settings
4. Select myMaps
nulo
