Testing Text Messaging on an inReach Handheld
It is recommended to test both that your subscription service is active and that you can send out a text message. Sending out a test text message will ensure that your inReach is working properly before you take it out into the field. You can find instructions to test your inReach service is active by visiting Testing inReach Service to Verify Active Subscription.
To test the messaging service, follow the recommended guidelines of utilizing Preset Messages below.
NOTE: Remember that while outbound Preset Messages do not count against any plan, any reply will count against the subscriptions plan if you are on a Safety or Recreation plan.
  1. Edit text and add recipients for a Preset Message.
  2. Sync your inReach with inReach Sync App (computer) or Garmin Earthmate App (mobile).
  3. Take your inReach outside with a clear view of the sky and send the Preset Message.
If the Preset Message was successfully received, your inReach is working properly.
