Performing a Soft Reset on the Tread®
A soft reset can help by forcing the device to reboot if it will not power on, or if the screen has become frozen and will not power off.
To Perform a Soft Reset:
  1. Connect the device to the powered mount
    • An A/C adapter or automotive power cable may also be used.
  2. Press and hold the power button and slowly count to 20
The device should now turn on. Leave the device connected to power to give the battery time to charge.
See Updating Automotive Maps and Software with Garmin Express on a Tread Device if your touchscreen is not responding correctly to update the software.
The Videos Below are a Quick and Easy way to Learn about Updating the Device with Wi-Fi.
