Searching for Tides on a GPSMAP 66/67 Series Device
Tide station information includes the tide height, and when the next high and low tides will occur. If you would like to find Tide Information for your area, you will need to select the nearest Tide Station to your location on your GPSMAP 66/67 series handheld device. There is also the option to view the tide information on a different date, as well as viewing a chart that shows the height of the tides throughout the day.
Viewing Tide Information
  1. Press FIND.
  2. Select Tides from the menu.
  3. Select the closest Tide Station.1
  4. Press the MENU.
  5. Select Review Point to view the Tide Chart for the current date.
  6. Press the MENU and select Hide Chart to show the heights and times of the tides for the day.
  7. Press the MENU and select Change Date to select a different date to view the tide information on that date.
    • Use the left and right arrows to change the date, and press ENTER to select that date.
1 The device will list US Tide Stations within a 200-mile radius and they will be listed by their proximity to your location. The nearest Tide Station will be at the top of the list. If needed, the "Search Near" function can be used to change the search location (see Viewing Distant Points of Interest or Addresses on a GPSMAP 66/67 Series).
