Add Via Point on the StreetPilot® c300 Series
In order to add a via point to your route on a StreetPilot® c300 series device, follow the steps below.
With the device powered on
  1. Touch Where To?
  2. Touch any of the available Where To? menu options and search for your final destination
  3. Touch Go!
  4. Touch Menu once the route has calculated
  5. Touch Where To?
  6. Touch any of the available Where To? menu options and search for your via point
    • If you have selected the Browse Map option, touch the map to create a pointer
    • Use the buttons on the screen to pan and zoom on the map to the desired location to make your via point
  7. Touch yes when asked to confirm that you'd like to travel to your destination by way of the location selected in the search
The device will now route you to your final destination by way of the location you entered.
