Delta SE: Pairing and Limitations
It is possible to pair the Delta® SE model dog device to another Delta-series handheld or to a Pro-series handheld. Some of the collar training functions will only work with the original model handheld with which it was intended to be used. Tone and vibration will work the same for any handheld and collar combination. There can be minor variances in the intensity levels of the electronic stimulation from handheld to handheld.
NOTE: The Delta SE does not have the ability to enable BarkLimiter™ features from the handheld.
Compatibility and Limitations
Delta SE Handheld
The Delta SE handheld is compatible with the following collars, but there are limitations in the collars use when paired to the Delta SE handheld. Tone and vibration will work the same for any handheld and collar combination. There can be minor variances in the intensity levels of the electronic stimulation from handheld to handheld.
Delta SE Dog Device
No option for BarkLimiter to be set from handheld.
Delta XC/Delta Sport™ XC Dog Device
Will not have the option for Momentary (M) correction. Tone, Vibrate and Continuous will still work.
Pro Series Handheld
The following Pro Series handhelds are compatible with the following collars, but there are limitations in the collars use when paired to the handheld. Tone and vibration will work the same for any handheld and collar combination. There can be minor variances in the intensity levels of the electronic stimulation from handheld to handheld.
Pro Series Dog Training Handhelds
Sport® Pro
Pro 550
Pro 70
Compatible Collars and Their Limitations
Delta SE Dog Device
No option for BarkLimiter to be set from handheld or collar.
No beacon lights.
Delta Sport/Delta Sport XC Dog Device
PT 10
Beacon Lights available, able to be turned on from the handheld. Please see specific handheld for guidelines on use.
BarkLimiter feature available to be set from the collar.
Delta SE Dog Device
No BarkLimiter feature.
BarkLimiter features set through Delta Sport XC handheld.
