Setting up the Dexcom Connect IQ Data Field
Once the Dexcom Data Field has been downloaded from the Connect IQ™ store, there are some steps to complete in order to see your glucose number recorded by your Dexcom Continuous Glucose Monitoring System on your Garmin® device. The Dexcom apps in the Connect IQ Store are software-only applications for compatible Garmin smartwatches and Edge® cycling computers, intended to provide a secondary display of continuous glucose monitoring (CGM) data to users of compatible Dexcom continuous glucose monitors for the purposes of passive monitoring.
The Dexcom Data Field shows blood glucose levels and trends during an activity on your compatible Garmin device. Below are samples of what you may see along side your activity information:
Dexcom Data Fields on watches and Edge
NOTICE: If you are having an issue with Dexcom data not displaying on your Garmin device see:  Dexcom Data Is Not Updating or Displaying on My Garmin Product
Dexcom apps are available for customers with a compatible Garmin device in select Regions. For details see Garmin Dexcom Connect IQ App Region Compatibility. You can also visit https://www.garmin.com/DexcomUse for more information.
Setting Up The Dexcom Data Field
To complete the setup, your Garmin device must be connected in the Garmin Connect™ app on your smartphone. For pairing instructions, refer to your owner's manual.
Select your device below to reveal instructions for setting up the Dexcom Connect IQ data field:
D2™ Air X10 Watch
  1. Press Start and select an activity profile.
  2. Swipe up to access the activity menu.
  3. Select Settings.
  4. Select Data Screens.
  5. Select a screen to customize.
  6. Select Edit Data Fields.
  7. Select a data field to customize.
  8. Select Connect IQ Fields.
  9. Select Dexcom Data Field.
  10. Press the back button four times to return to the activity profile home page.
  11. Swipe up to access the profile menu.
  12. Select Connect IQ Fields.
  13. Select Dexcom Data Field.
  14. Select OK to begin the sign-in process.
  15. Scroll through and accept Usage Notice.
  16. Open the Garmin Connect app when prompted.
    • Android: The Dexcom login page automatically opens.
    • iOS: Select Sign In on the Dexcom login prompt.
  17. Sign in with your Dexcom username and password.
  18. Accept the usage terms and e-sign.
  19. Return to your watch to complete the sign-in process.
You have now enabled the Dexcom data field on your watch.
Edge® Cycling Computers
Edge® 530
  1. From the home screen, press the Down button to access the menu.
  2. Select Settings.
  3. Select Activity Profiles.
  4. Select a profile.
  5. Select Data Screens.
  6. Select a screen to customize.
  7. Select Layout and Data Fields.
  8. Select a layout.
  9. Select a data field to customize.
  10. Select Connect IQ.
  11. Select Dexcom Data Field.
  12. Select Yes to edit data field settings.
  13. Select OK to begin the sign-in process.
  14. Scroll through and accept the Usage Notice.
  15. Open the Garmin Connect app when prompted.
    • Android: The Dexcom login page opens automatically.
  16. Sign in with your Dexcom username and password.
  17. Accept the usage terms and e-sign.
  18. Return to your Edge to complete the sign-in process.
You have now enabled the Dexcom data field on your Edge 530.
Edge® 540 Series | Edge® 550 | Edge® 830 | Edge® 840 Series | Edge® 1030 | Edge® 1030 Plus | Edge® 1040 | Edge® 1040 Solar | Edge® Explore 2
  1. From the home screen, press 3 lines menuto access the menu.
  2. Select Activity Profiles
  3. Select a profile.
  5. Select the screen you want to customize.
  6. Select Layout and Data Fields.
  7. Select a layout.
  8. Select a data field to customize.
  9. Select Connect IQ.
  10. Select Dexcom Data Field.
  11. Select the checkmark to edit the data field settings.
  12. Select OK to begin the sign-in process.
  13. Scroll through and accept the Usage Notice.
  14. Open the Garmin Connect app when prompted.
  15. Sign in with your Dexcom username and password.
  16. Accept the usage terms and e-sign.
  17. Return to your Edge to complete the sign-in process.
You have now enabled the Dexcom data field on your Edge.
Edge® 850 | Edge® 1050
  1. Select Three horizontal lines in red circle to access the menu.
  7. Select tick mark to confirm layout.
  8. Select the location of the field you would like.
  11. Select tick mark to confirm the data field settings.
You have now enabled the Dexcom data field on your Edge 1050
Forerunner® Watches
  1. Select the Start button and select an activity profile.
  2. Select and hold the Up button (or scroll down for some models) to access the activity menu.
  3. Select the profile settings (Example: Run Settings).
  6. Select Data Fields.
  7. Select a field to customize.
  10. Select Start to edit the data field settings.
  11. Select Down to begin the sign-in process.
  12. Scroll through and accept the Usage Notice.
  13. Open the Garmin Connect app when prompted.
  14. Sign in with your Dexcom username and password.
  15. Accept the usage terms and e-sign.
  16. Return to your watch to complete the sign-in process.
Outdoor Watches
D2™ Watches
D2™ Delta | D2™ Delta PX | D2™ Delta S
  1. Select START/STOP and select an activity profile.
  2. Hold UP to access the activity menu.
  10. Press START/STOP to edit data field settings.
  11. Press DOWN to begin the sign-in process.
D2™ Mach 1 | D2™ Mach 1 Pro
Enduro™ | Enduro™ 2 | Enduro™ 3
  1. Select START/STOP (upper right button) and select an activity profile.
  2. Hold UP (middle left button) to access the activity menu.
  10. Press START/STOP (upper right button) to edit data field settings.
  11. Press DOWN (lower left button) to begin the sign-in process.
epix™ (Gen 2) | epix™ (Gen 2) Sapphire | epix™ (Gen 2) Porsche Edition
epix™ Pro (Gen 2) - Standard Editions | epix™ Pro (Gen 2) - Sapphire Editions
fēnix® Watches
fēnix® 6 Standard Edition and All Other Watch Models in the fēnix 6 Series
fēnix® 7 Standard Edition and All Other Watch Models in the fēnix 7 Series
  10. Select Yes to to select edit data field settings.
fēnix® 7 Pro Solar Edition and All Other Watch Models in the fēnix 7 Pro Series
fēnix® 8 Series and fēnix® E Watches
  1. Select START/STOP (upper right button) and select an activity profile. (Example: Run)
  2. Select Activity Options.
  3. Select Data Screens.
  4. Select a screen to customize.
  5. Select Data Fields
  6. Select a field to customize.
  7. Select Connect IQ Fields.
  8. Select Dexcom Datafield.
  9. Select START/STOP to edit data field settings.
  10. Select DOWN (lower left button) to begin the sign-in process.
  11. Scroll through and accept the Usage Notice.
  12. Open the Garmin Connect app when prompted.
  13. Sign in with your Dexcom username and password.
  14. Accept the usage terms and e-sign.
  15. Return to your watch to complete the sign-in process.
MARQ® Collection
  1. Press START/STOP and select an activity profile.
MARQ® Collection (Gen 2)
quatix® 6 | quatix® 6X Solar | quatix® 6 Titanium | quatix® 6 Pro | quatix® 7 | quatix® 7X Solar
tactix® Watches
tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta Solar Edition with Ballistics
tactix® 7 - AMOLED Edition | tactix® 7 Standard Edition | tactix® 7 Pro Edition | tactix® 7 Pro Ballistics
tactix® 8 - AMOLED Editions | tactix® 8 - Solar Editions
  2. Select Activity Options or "Activity Name" Settings. (Example: Run Settings)
Venu® Watches
The steps below applies to all Venu models.
  3. Select Settings.
vívoactive® 4 | vívoactive® 4S | vívoactive® 5
  3. Select Settings.
vívoactive® 6
  1. Press the top button and select an activity profile.
  2. Swipe and select the activity settings.
  4. Select the data field you want to customize.
  5. Swipe and select Connect IQ Fields.
  6. Select Dexcom Data Field.
  7. Tap on the checkmark.
  8. Select OK to begin the sign-in process.
  9. Scroll through and accept the Usage Notice.
  10. Open the Garmin Connect app when prompted.
  11. Sign in with your Dexcom username and password.
  12. Accept the usage terms and e-sign.
  13. Return to your watch to complete the sign-in process.
IMPORTANT: Updated information will only be provided when your compatible smartphone has a data connection and is in BLE range of both the Dexcom CGM and Garmin smartwatch or Edge® cycling computer. For more details, visit the Dexcom CIQ app page.
Dexcom Data Field Instructional Video for an Edge Cycling Computer
Dexcom Data Field Instructional Video for an Outdoor Watch
Dexcom Data Field Instructional Video on a Wellness Watch
Related
