Error "System Missing" or "Software Missing" When Powering On a Garmin Marine Chartplotter
If a Garmin marine chartplotter displays the error message System Missing or Software Missing while the device is being powered on, this is generally due to an issue with the internal operating software of the device.
To correct the issue, a software update needs to be applied to the device using the forced update procedure.
For instructions on how to update the device software, see Related Content.
If the forced update does not correct the issue, the device will need to be sent in for repair. Contact Garmin Product Support to setup a Return Material Authorization.
Related
