Install Maps to Garmin Devices using MapSource
There are many situations where it may be desirable to install additional maps to a Garmin GPS. MapSource® software should only be used when working with outdoor handhelds that use a serial port connection to a computer. Newer handhelds that use a USB computer connection should use BaseCamp™ software.
MapSource software is available for Windows only1 and can be downloaded for free from the MapSource page of the Garmin website. MapSource software cannot be installed on your computer without a previous version of maps already on the computer.
Loading Maps to Your Garmin Device Using the MapSource Program
- Attach your Garmin device to the computer with a data transfer USB cable.
- Start MapSource program.
- Click the Tools menu.
- Click the Map option in the Tools menu.
- Click the map regions you wish to install.2
- Click the Transfer menu.
- Click the Send To Device option in the Transfer menu .
- Ensure that the device appears in the Device field below the Find Device button.3
- Click Send.
This may take several minutes to load to the device, depending on the size of the maps. After MapSource software has finished loading maps to the device, you may disconnect the GPS, and the maps will be available for use on the device.
1 To load maps to a Garmin device from a Mac, see Related Content.
2 Each time maps are loaded to a device, it replaces any maps that had been previously loaded (excluding maps that were preloaded to the device when purchased), so be certain to select all of the maps needed on the device.
3 If your device is not listed, check the connection between the device and the computer, and click the Find Device button. If you continue to have connection issues, see Related Content.
