What Type of Antenna Should I Use for DAB/DAB+ Radio on the MS-RA60?
The MS-RA60 has a built-in DAB module and no external module is required. Connect an appropriate AM/FM antenna to the Motorola-type antenna port on the stereo to enable DAB/DAB+ streaming in Europe and Australia (does not support traffic and weather). If the stereo is being installed on a boat with a metal hull, a ground-dependent antenna must be used. A ground-independent antenna must be used on a boat with a non-metal hull.
