- The Bluetooth icon should be displayed in the status bar next to the battery charge indicator.
Alpha 200 Plus or Alpha 300 Series Not Staying Bluetooth Connected to the Alpha App
If you are having trouble getting the Alpha® 200 Plus, Alpha 300, or Alpha 300i dog tracking handheld to stay connected to the Alpha Mobile app, there are a few things to look for.
Check That the Bluetooth for the Alpha Handheld Is Turned On
Make Sure the Software on the Alpha Handheld Is Up to Date
- Use Garmin Express™ software from a computer, which will automatically check for and install available software updates.
- For a step by step guide on updating with Garmin Express software, see - Software Updates for Alpha 300 and Alpha 300i
Check For and Install Any Available Updates for Your Phone
- Consult your phone manufacturer for assistance if needed.
Miscellaneous Items to Check
- Make sure that Airplane Mode is turned off on your mobile device.
- Select Devices in the Alpha Mobile app and verify that the Alpha 300 handheld shows Connected.
Troubleshooting Steps for Connection Issues
Attempt unpairing and pairing the two devices again.
- Select Forget Phone in the Bluetooth Settings of the Alpha handheld.
- Navigate to the Main Menu on the Alpha handheld.
- Select Setup.
- Select Bluetooth.
- Select Forget Phone.
- Select Yes.
- Select Remove Device in the Garmin Devices section of the Alpha Mobile app.
- Select device.
- Select 3 dots in upper right corner.
- Select Remove Device.
- Forget the Alpha handheld in the Bluetooth Settings of your phone or tablet.
- Consult your phone manufacture for assistance if needed
- Restart both the Alpha handheld and the phone or tablet.
- Pair the Alpha handheld back to your mobile device in the Alpha Mobile app.
