Troubleshooting inReach Sync for the inReach Mini
When connecting the inReach® Mini satellite communicator to your computer to sync, the device should indicate it is charging, and the inReach Sync desktop app should display a color image of the connected device. For specific steps on syncing, refer to the Install inReach Sync section below.
If the inReach Sync app fails to establish a connection between an inReach Mini and the computer, use the troubleshooting below. For specific inReach Sync errors, see Related .
IMPORTANT: Mac users may need to be under the admin user profile for inReach® Sync to work properly. For how to switch profiles, see - Apple Support - Switch Quickly Between Users on Mac. If further assistance is needed with this process, contact Apple Support.
Confirm Garmin Express™ Program is Closed
To sync data from the Garmin Explore™ website to an inReach® satellite communicator using a computer, the inReach Sync Desktop App should be installed on a Windows or Mac computer.
  1. Log into Garmin Explore website.
  2. Select Plans & Devices tab.
  3. Select Sync & Update.
  4. Select the Windows or Mac link below inReach Sync Desktop App.
    • An installation file will be downloaded.
  5. Locate the file on your computer and run it.
    • Windows: The file will usually be located in the Downloads folder.
    • Mac: The file should appear on the Desktop.
  6. Follow the on-screen prompts to complete installation.
For steps on updating inReach firmware and syncing account changes, see - Updating the Firmware and Syncing Account Information to an inReach Mini.
Confirm Your Login Information in inReach Sync
In order to sync any account related information or settings, you must log in to inReach Sync with the e-mail address associated with the inReach device. If you are not logged in, or if you are logged in with the wrong e-mail address, an error will typically occur. For more details and steps for logging out and back in, see - Unknown Device Error When Using inReach Sync.
Different USB Port
Many inReach® Sync issues are the fault of a problematic or faulty USB port. Before proceeding with any additional troubleshooting steps first re-connect the inReach to a different USB port on your computer and re-open inReach Sync to test to confirm if the issue has been resolved.
NOTE: If using a desktop computer make sure to connect the inReach device to a USB port located on the back of the computer tower. Do not use a USB hub connection if at all possible.
Different USB Cable
An inReach® satellite communicator uses a non-proprietary micro-USB to USB connector cable to communicate with the inReach Sync program. If inReach Sync cannot connect to the inReach device after completing the above steps, test the connection between the inReach device and computer with a different micro-USB to USB cable. When looking for a cable to test with remember that many other electronic devices such as some phones or cameras use same connectors to communicate with a computer.
The inReach Sync icon and/or the inReach device icon will appear faded if there is an issue with USB cable.
NOTE: When selecting a micro-USB to USB cable for the inReach Sync connection make sure that the cable is advertised as working as both a charger and a data transfer cable. If the cable is only rated for power transfer and charging the inReach Sync program will not recognize the connected inReach device.
USB Hub
As with trying a different USB port or cable, if you are connecting to a USB hub, for example with a laptop that connects USB devices through a hub, it's important to ensure the port to which you're connecting is cable of processing data exchange with the computer and is not simply for charging or some other purpose.
Soft Reset the inReach Mini
  1. Disconnect the inReach Mini from the computer.
  2. Press and hold Back Button inReach Mini and Power until the inReach Mini powers off.
  3. Power on the inReach Mini.
  4. Connect the inReach Mini back to the computer.
  5. Open inReach Sync and test to confirm that the issue has been resolved.
Firmware Update Mode
NOTE: When using Firmware Update Mode, Garmin Express should be used instead of inReach Sync. For more information, see: What is Garmin Express?
  1. Disconnect the inReach Mini from the computer, and power the inReach Mini off.
  2. Press and hold Black Up Arrow on White Background, Black Back Arrow on White Background, and Power simultaneously.
  3. The device will power on into Firmware Update Mode, with the display showing:
    White USB Trident Symbol on Black Background
  4. Connect the inReach Mini to the computer.
  5. Open Garmin Express and install any updates available.
    NOTE: If needed, select Add Device.
  6. Disconnect the inReach Mini and test to confirm the issue is resolved.
Uninstall/Reinstall inReach® Sync
Windows Vista/7
  1. Click on Start.
  2. Select Control Panel.
  3. Select Uninstall a program.
  4. Find the application called inReach Sync.
  5. Select Uninstall.
  6. Restart the computer.
Windows 8.1/10
  1. Right-click on the Start menu.
  2. Select Apps & Features.
  3. Find the application called inReach Sync.
  4. Select Uninstall.
  5. Restart the computer.
Windows 11
  2. Select Installed apps.
  4. Select Three Dots Professional, then Uninstall.
Mac
  1. In Finder, go to the Go menu on the top menu bar.
  2. Select Applications.
  3. Find inReach Sync.
  4. Click/drag to the Trash Can to remove.
  5. Empty the Trash Can.
Once completed, follow the steps below to download and install inReach® Sync.
NOTE: Be sure to reboot or restart the computer after the app has been reinstalled.
Factory Reset Device
IMPORTANT: A factory reset will delete all contact, message, waypoint, route, and logging data stored on an inReach device. Only use this option if all of the previous potential solutions have been tried. Before resetting the device try pairing and syncing using the Earthmate® app, see below
  1. Power on the inReach Mini.
  2. Press OK to open the main menu.
  3. Select Setup.
  4. Select Recovery Options.
  5. Select Restore Defaults.
  6. Press OK.
  7. Select Reset.
    NOTE: The inReach Mini will reset and reboot.
  8. After the inReach Mini reboots, connect the inReach Mini to the computer.
  9. Open inReach Sync and test to confirm that the issue has been resolved.
As an alternative, if you still are unable to sync using the inReach Sync desktop app, you can try pairing and syncing using the Earthmate app. For steps, see - Pairing Instructions for Earthmate Compatible inReach Devices and Syncing inReach Account Changes with the Earthmate App.
If you are looking for troubleshooting steps for inReach Sync with other inReach models, select the model: inReach Explorer and SE or inReach Explorer+ and SE+
Related
