Garmin Radar Display Mode and Feature Compatibility
Many Garmin chartplotters can connect to a compatible GMR™ marine radar to aid in navigation using the various radar features.
NOTES:
• The ability to access a specific radar feature depends on the correct combination of chartplotter and GMR.
• ECHOMAP™ chartplotters are not compatible with any GMR.
• A new GMR paired with an older GPSMAP™ chartplotter may not be compatible. The functional design, software, and functionality of an older GPSMAP chartplotter may not process all the features a new GMR can produce.
GPSMAP™ 10x2 chartplotters | GPSMAP™ 12x2 chartplotters
GPSMAP™ 7x3 chartplotters | GPSMAP™ 9x3 chartplotters | GPSMAP™ 12x3 chartplotters | GPSMAP™ 16x3 chartplotters
GPSMAP™ 84xx chartplotters | GPSMAP™ 86xx chartplotters | GPSMAP™ 8700 chartplotter
GPSMAP™ 90xx chartplotters | GPSMAP™ 92xx chartplotters
  • GMR Fantom™
    Open Arrays
    GMR Fantom™
    Domes**
    GMR™
    Domes**
    GMR™  Domes**
    GMR™  Open Arrays
    GPSMAP series listed above
     GMR Fantom™  54
    GMR Fantom™  56
    GMR Fantom™  124
    GMR Fantom™  126
    GMR Fantom™  254
    GMR Fantom™  256
    GMR Fantom™ 18x
    GMR Fantom™  24x
    GMR™ 18HD3
    GMR™ 18x HD3
    GMR™  24xHD3
    GMR™ 434 xHD3
    GMR™ 436 xHD3
    GMR™ 1234 xHD3
    GMR™ 1236 xHD3
    GMR™ 2534 xHD3
    GMR™ 2536 xHD3
    DYNAMIC AUTO GAIN
    X
    X
    X
    X
    X
    DYNAMIC SEA FILTER
    X
    X
    X
    X
    X
    DUAL-RANGE OPERATION
    X
    X
    X
    X
    DUAL-RADAR SUPPORT
    X
    X
    X
    X
    X
    DUAL RANGE WITH OVERLAY
    X
    X
    X
    MARPA TARGET TRACKING*
    X
    X
    X
    X
    X
    NO TRANSMIT ZONE
    X
    X
    X
    X
    RADAR OVERLAY
    X
    X
    X
    X
    X
    PULSE EXPANSION
    X
    X
    BIRD GAIN
    X
    X
    X
    X
    ECHO TRAILS
    X
    X
    X
    X
    GUARD ZONE
    X
    X
    X
    X
    X
    VRM AND EBL
    X
    X
    X
    X
    X
    TARGET SIZE
    X
    X
    X
    X
    SCAN AVERAGING
    X
    X
    X
    X
    MOTIONSCOPE
    X
    X
    HARBOR
    X
    X
    X
    X
    X
    OFFSHORE
    X
    X
    X
    X
    SINGLE RANGE
    X
    X
    X
    X
    X
    SENTRY
    X
    X
    X
    X
    X
    TRUE COLOR
    X
    X
    X
    X
    X
    PROGRAMMABLE ANTENNA PARKING
    X
    X
    X
    POWER SAVE MODE
    X
    60 RPM ROTATION
    X
    X
    TIMED TRANSMIT
    X
    TARGET SHAPE ENHANCEMENT
    X
    X
    X
*Requires a heading sensor, sold separately
**Compatible with GPSMAP™ 7x3 chartplotters | GPSMAP™ 9x3 chartplotters | GPSMAP™ 12x3 chartplotters | GPSMAP™ 16x3 chartplotters | GPSMAP™ 10x2 chartplotters | GPSMAP™ 12x2 chartplotters | GPSMAP™ 8400 chartplotters | GPSMAP™ 8600 chartplotters
RADAR Feature Definitions:
  • DYNAMIC AUTO GAIN: Gain levels automatically adjust to optimum settings for harbors, nearshore, and offshore in open waters
  • DYNAMIC SEA FILTER: Gain automatically adjusts sea clutter for calm, medium, and rough sea conditions
  • DUAL-RANGE OPERATION: This feature enables the fully independent split-screen display of far and near radar views
  • DUAL-RADAR SUPPORT: Using dual radar provides redundancy and allows each display unit on the boat to pull data from one of two different radar sources
  • DUAL-RANGE WITH OVERLAY: Single radar antenna can provide split-screen images on the chartplotter side by side, with independent range settings and controls for close and long-range. One or both ranges can be viewed as a chart overlay
  • MARPA TARGET TRACKING: This radar provides MARPA target tracking when combined with a multifunction display and heading sensor (sold separately)
  • NO TRANSMIT ZONE: Use to protect areas behind the radar from being radiated while providing full forward-looking radar capability. The no transmit zone also makes installation more flexible.
  • RADAR OVERLAY: Overlay radar images onto the chartplotter’s map page. Add an optional autopilot or heading sensor (sold separately) for best results
  • MARPA TARGET TRACKING: GMR provides MARPA target tracking when combined with a multifunction display and heading sensor (sold separately)
  • PULSE EXPANSION: Increase the duration of the transmit pulse, which helps maximize the energy on targets. Pulse expansion provides a more prominent target size on the chartplotter
  • AUTO BIRD GAIN: Locate flocks of birds at the water’s surface where baitfish are also likely to be found
  • ECHO TRAILS: A historical “trail” is left on the screen to help in quickly and easily identifying moving targets and potential collision threats
  • GUARD ZONE: Set the safety zone and receive an alarm when an object enters the zone
  • VRM AND EBL: Variable range markers (VRM) and electronic bearing lines (EBL) allow rapid measurements of distance and bearing to vessels and land
  • TARGET SIZE: Adjust the size of objects on the radar image
  • MOTIONSCOPE: MotionScope technology uses the Doppler effect to detect and highlight targets moving toward or away from the vessel in different colors to help avoid collisions, find flocks of birds, and track weather
  • CRUISING MODE: This shows a full-screen image of the gathered radar information
  • HARBOR MODE: Use harbor mode for inland waterways. It works best with short-range signals (2 nm or less)
  • OFFSHORE MODE: Use in open waters; this mode works best with long-range signals
  • SENTRY MODE: Puts the radar into a timed-transmit mode, configuring a transmit and standby cycle to conserve power. Enables a guard zone in this mode, identifying a safe zone around the boat. By switching from Sentry mode to another mode, the radar switches to full-time transmission and disables all guard zones
  • RADAR OVERLAY MODE: This shows a full-screen image of the gathered radar information on top of the Navigation chart. The Radar overlay displays data based on the most recently used radar mode
  • POWER SAVE MODE: Users can customize and prioritize power draw or performance
  • TIMED TRANSMIT: Users can set the transmit intervals to seconds rather than minutes
  • 60 RPM ROTATION: Allows a faster screen refresh rate for smoother target tracking (High Sped 60 RPM, Normal Speed 24 RPM). The GMR will use the “High Speed” setting to adjust to the highest available, up to 60 RPM, but it will be lower depending on range and drop down to 24 RPM if MotionScope or dual channel modes are enabled
  • TARGET SHAPE ENHANCEMENT: Utilized for attaining better target separation. Use the “Largest and Smallest” settings from the menu for fine-tuning. Use this feature with “Gain”
Related
