(2024) Service Bulletin 24009 Rev A: GSA 28 Software Version 5.46
PRODUCTS AFFECTED:
GSA 28 units with software versions earlier than 5.46 installed in the following systems are affected:
  • GFC 500 systems installed using Approved Model List (AML) Supplemental Type Certificate (STC) SA01866WI
  • G3X Touch systems installed using Approved Model List (AML) Supplemental Type Certificate (STC) SA01899WI
  • G5 installed using Approved Model List (AML) Supplemental Type Certificate (STC) SA01818WI
  • GI 275 installed using Approved Model List (AML) Supplemental Type Certificate (STC) SA02658SE
CERTIFICATION AUTHORIZATION:
STC SA01866WI MDL Revision 84, STC SA01899WI MDL Revision 16, STC SA01818WI Revision 32, SA02658SE MDL Revision 23
COMPLIANCE:
Recommended: Compliance with STC Service Bulletin 24009 is recommended at the next maintenance interval.
DOCUMENTATION CONSIDERATIONS:
As a result of changes related to this update, the applicable documents listed in Table 1 are required to be issued to the aircraft operator/owner before the aircraft is returned to service.
Table 1
Document TitlePart NumberRevision (or later)
GFC 500 Autopilot with Electronic Stability and Protection Part 23 AML STC Maintenance Manual Includes Instructions for Continued Airworthiness for STC SA01866WI190-02291-0112
Garmin G3X Touch EFIS Part 23 AML STC Maintenance Manual Contains Instructions for Continued Airworthiness190-02472-029
Airplane Flight Manual Supplement or Supplemental Airplane Flight Manual for the Garmin G3X Touch Electronic Flight Instrument190-01754-016
G3X Touch Pilot’s Guide for Certified Aircraft190-02472-00F
Garmin G5 Electronic Flight Instrument Part 23 AML STC Maintenance Manual Including Instructions for Continued Airworthiness190-01112-1110
Airplane Flight Manual Supplement or Supplemental Airplane Flight Manual for the Garmin G5 Electronic Flight Instrument190-01112-139
G5 Electronic Flight Instrument Pilot’s Guide for Certified Aircraft190-01112-12L
GI 275 Part 23 AML STC Maintenance Manual/ICA190-02246-118
GI 275 Part 23 AML STC Airplane Flight Manual Supplement190-02246-1211
GI 275 Pilot’s Guide190-02246-01P
PURPOSE:
This STC Service Bulletin announces the approval of GSA 28 Software Version 5.46. This software version fixes an intermittent issue that prevents the GSA 28 Servo from engaging.
WARRANTY INFORMATION:
This modification is warranty reimbursable with a deadline of August 30, 2024.
