Garmin Explore App Hunt Collections on Dog Devices
The Garmin Explore™ App utilizes collections to organize your hunt data. Every time you start a new hunt, a new HUNT collection is created. These Hunt Collections show when you sync your device with the Explore App
Under the library The collection name will be titled with the date and time the hunt was created. Any time the device is powered on and off it will create a new hunt collection. The handheld will sync automictically when you power it on and open the app. Under each collection you will see icons that let you know how many of each item are in that collection. It shows activities, waypoints, routes, courses and tracks.
To View a collection tap on the collection in the list. With the collection open you will see a list of all devices associated with that collection. Activity colors will match what the handheld is set to.
To view a specific activity tap on that activity. From here you will see activity data such as a map view of the activity, length, duration, time started, Date started, and number of points
In order to delete an entire collection use the following instructions,
- Touch the Collection to delete.
- Touch the Three Dots in the upper right hand corner.
- Touch Delete
In order to delete a specific activity, follow the steps below
- Touch on the Collection containing the activity to be deleted.
- Touch on the Activity to be deleted
- Touch the Three Dots in the upper right corner
- Touch Delete.
