Adding and removing map buttons on automotive devices
Your Garmin device allows you to customize which buttons will appear on the right-hand side of the View Map screen.
To customize the map buttons:
  1. Touch Settings
  2. Touch Map & Vehicle
  3. Touch Map Buttons
  4. Touch the map button to remove
    • The maximum number of buttons allowed is three for this device.
  5. Touch an empty button (displays as a +)
  6. Touch the desired map button
  7. Touch Save once the desired buttons have been set
    • Touch Cancel to discard changes and use the current map buttons
    • Touch Reset to Defaults to return to the default map buttons
The map buttons are now set to your preference.
