1. Open the Garmin Drive app
- You may need to first enable your phone's Bluetooth
- Refer to the owner's manual for your phone if you are not sure how to enable Bluetooth
2. In the Drive app, if prompted, check the agree to the terms and touch Next
3. Agree to the Warning
4. Touch Navigation Device in the Garmin Drive app
5. On the Garmin device, touch Settings
6. Touch Wireless Networks
7. If no checkmark is present, check the box next to Bluetooth
8. Touch Pair when prompted on your phone
9. Touch Yes if prompted on the Garmin device
10. Touch OK if prompted
11. If prompted, touch Continue to agree to the Privacy Policy:
12. Touch Sign In. If you don't have an account touch Create Account
13. Pairing is now complete. Touch Continue to start the setup of the Alexa features.
14. Touch Continue for audio setup
15. Touch Yes or No depending on if you use Bluetooth to connect your smartphone to your vehicle or not
16. If you selected 'No' to Bluetooth connection with your car, touch Continue and proceed to step #22 below.
17. If you selected 'Yes' and can play music from your phone to your vehicle
(You will need to have your phone connected with your vehicle via Bluetooth to complete the calibration).
18. Touch Continue to calibrate the Bluetooth audio
19. Touch OK to start the audio calibration if prompted.
20. Touch Play Test Sound
- Allow permission for Drive to record audio if prompted.
21. Touch Continue when audio setup is complete
- Follow the prompts to sign into your Amazon account or Create an Amazon account and allow Drive app access to voice services.
- NOTE: Signing into an Amazon Alexa account (activating Alexa) is required in the set up process of the Garmin Drive app. There would not be any way to disable the feature other than to remove the device from the Garmin Drive app or disable the Bluetooth pairing between the phone and the device.
23. Touch Next
24. Follow the prompts to set or skip Notification Permissions for:
- Smart Notifications
- Display Media Permission
25. The device will now be ready to use in the Garmin Drive app
