(2025) Service Bulletin 25009 Rev A: G1000® NXi STC Update for Textron Aviation Model 510 Mustang
PRODUCTS AFFECTED:
Textron Aviation Inc. Model 510 Mustang aircraft equipped with G1000 NXi Integrated Flight Deck per STC SA01896WI are affected.
CERTIFICATION AUTHORIZATION:
STC SA01896WI MDL Revision 7
COMPLIANCE:
Recommended: Compliance with this STC Service Bulletin is recommended at the next scheduled maintenance interval.
DOCUMENTATION CONSIDERATIONS:
Documents listed in Table 1 are required to be issued to the aircraft owner/operator before the aircraft is returned to service, if not already provided.
Table 1. Document Considerations
Document Title | Part Number | Revision (or later) |
Airplane Flight Manual Supplement G1000 NXi Integrated Avionics System and GFC 700 AFCS in Citation Mustang Model 510 | 190-02450-02 | 2 |
G1000 NXi Pilot's Guide Cessna Mustang | 190-02522-01 | A |
G1000 NXi Cockpit Reference Guide Cessna Mustang | 190-02523-01 | A |
PURPOSE:
This STC service bulletin provides notification of System Software Version 413.45, which provides the following:
- Fixed an ADS-B TSO non-compliance issue as described in Garmin Service Advisory 23033
- Fixed GWX Processor software load not reporting issue
- Added support for loading optional GSR software
- Added support for LFE (Landing Field Elevation) population from the flight plan
- Added support for Flight Stream 510 configuration mode
- Added support for Flight Stream 510 wireless and Connext libraries
WARRANTY INFORMATION:
Modification of affected units is covered under the Garmin factory warranty with a deadline of September 30, 2025.
