Finding the Serial Number on your BarkLimiter Deluxe
Finding the Serial Number on Your BarkLimiter™ Deluxe Collar
Select the model of your BarkLimiter collar below to find how to locate your serial number.
BarkLimiter Deluxe
The serial number on the BarkLimiter Deluxe is located above the contact point.
                                               Barklimiter Deluxe SN
BarkLimiter
To located the serial number on the BarkLimiter you will need to remove the collar strap. You will see it located to the side of the battery compartment.
                                                             Barklimiter Serial Number
BarkLimiter 2 and BarkLimiter 2VT
To locate the serial number on the BarkLimiter 2 and 2VT you will need to remove the collar strap and collar band. The serial number is located above the molded BarkLimiter 2 name.
                              Barklimiter 2 Serial number
