Searching Near a Different Location on the Tread 2
By default, your device searches near your current location. If your device cannot find the destination you have entered, it may be searching in the wrong area.
To Search Near a Different Location:
1. Touch Search
Select Search
2. Touch the Near Me field
Select Near me
3. Touch Near a City or Select a Location.
 4. If Select a Location is touched, choose a location category to search within.
Search near options Tread 2
Available Search Options:
Near me- Searches near your current location (this is the default setting).
Near a City- Searches near a specific city you enter.
Home- Searches near the home address set on the device.
Address- Searches near an address entered on the device.
Recent- Searches near a recent location chosen from the recent list.
Waypoints- Searches near a location from the device's saved Waypoints.
Intersections- Searches near an intersection entered on the device.
Coordinates- Searches near a set of coordinates entered on the device.
Browse Map- Searches near a location selected on the map.
To begin searching near your current location once again, simply return to the main menu to restore the default setting.
If the errors "No Matches Found" or "Cannot Find Search Results" continue to appear when searching for a destination, try the following steps in order:
