Select Radio from the main menu.
Select
Select Setup Radio.
Select Send Location.
Select On.
Select Allow Polling.
Select On.
Send Location and Position Reporting Feature for Rino 600 and 700 Series
Utilizing sending and polling can enhance the Rino® outdoor handheld experience, and provide additional functionality while in the field. The Send Location feature allows you to send your current location to other Rino handhelds after each transmission. The Allow Polling feature permits other Rino handheld users to get your location by initiating a poll request on their Rino handheld to your Rino handheld.
Setting up the Rino Handhelds
To send your location or allow polling by others, confirm that all devices are set up identically with the items below:
From the Radio page, ensure channels and codes are the same on all Rino handhelds.
Check the Satellite page to make certain all Rino handhelds have acquired a GPS signal.
Turn Send Location and Allow Polling on:
From the main menu, use the thumb stick to select Radio.
Press
Select Setup Radio.
Select On.
Select On.
From the main menu, swipe up from the bottom of the screen to access the App Drawer.
Select Radio.
Select
Select Radio Setup.
Select Send Location to toggle on.
Select Allow Polling to toggle on.
Using Send Location and Allow Polling
Once all devices are set up, Send Location and Allow Polling can be used:
To poll the position of all Rino handhelds in range, press the Call key (located above the PTT key).
This sends out a call tone as well as a request for a position update on other users' positions.
To poll the position of a specific Rino contact, select a saved contact from the contacts app and then select Poll Location.
This sends out a request for a position update on the other user's position.
To send your location, press the PTT key (push-to-talk).
If held, this allows the user to communicate with other two-way radios using voice.
If tapped, it sends out a position update.
NOTE: Positions can only be updated once every 30 seconds. Rino 600/700 series devices will not work stably with Rino 100 series devices for the location or contact features.
