Garmin Dash Cam Power Issues, Frozen, or Not Powering On
Check the Following if a Garmin Dash Cam Won't Power On or is Having Power Issues, Freezes, or Experiences Freezing During Recording:
  • Ensure the vehicle power cable that came with the camera is being used
  • Ensure the vehicle power cable is plugged directly into a 12V power outlet or cigarette lighter outlet in the vehicle, rather than through a splitter or straight into a USB port
  • Update the camera software
  • If the vehicle is hot, allow it to cool down before plugging in the Dash Cam
  • Check the light on the end of the vehicle power cable and make sure it is lit
  • Connect the device to a power source with its Vehicle Power Cable
    • Press and hold the power button and slowly count to 30
    • An A/C adapter may also be used, but if the problem persists, the Vehicle Power Cable will need to be used
    • Remove the installed memory card, then press and hold the power button and slowly count to 30. If the camera displays a memory card error message, reinstall the memory card. If the issue persists, install a new memory card.
