Activate a Map Update to a Device Using a Product Key/Voucher Code
NOTES:
  • In accordance with the Lifetime Maps and Maps Terms and Conditions, map updates and/or Downloadable Content (DLC) are no longer available to download or purchase and cannot be activated and/or associated with the Garmin devices listed in Map Updates and Downloadable Content No Longer Available to Download or Purchase.
  • This is due to these devices not having sufficient memory capacity and other required technical capabilities to utilize current map data.
If you have purchased a onetime map update or a map update subscription from a local or online dealer, you may have received a Product Key/Voucher Code on a scratch-off card or via email. This Product Key/Voucher Code can be entered into Garmin Express™ in order to activate it to your device.
To Activate the Update:
1. Open Garmin Express™
See How Do I Install Garmin Express™? for installation instructions.
2. Follow the prompts on the screen to Add a Device to Garmin Express™
3. Click Tools & Content
4. Click the Purchased tab
5. Type the Product Key/Voucher Code in the Enter Voucher Code field, then click Redeem
6. Click Select
7. Click Confirm
8. Sign in to your myGarmin Account
The update will now be activated to your device.
Related
