Vaatad artiklit, mis ei ole praegu sinu valitud keeles saadaval. Allpool saad valida mõne muu keele.
How Do I Block Another User in Garmin Connect?
In the event that you want to block a user, Garmin offers this feature through your Garmin Connect™ account.
Choose your option below to reveal steps to block a user.
NOTE: Blocking a user will hide your data, except in Groups or Challenges you are in together (in which case it will only display the basic data of the challenge (i.e.-step count for a steps challenge). It also prevents future requests or invitations from the user.
Blocking a Connection
Garmin Connect Website
From a web browser, sign into your Garmin Connect account.
Select Connections from the navigation bar on the left.
Select the connection you want to block to view their profile.
Select the in the top right.
Select Block User.
Select Block.
Blocking a Non-Connection
Locate the user you want to block.
Blocking someone that is not a connection requires you to locate and view their profile page. You can access a user's profile by selecting their display name from a challenge, group, leaderboard, or comments section.
