Adjusting the Display on a Foretrex 101
The Foretrex® 101 outdoor device has the agility to adjust the timeout and contrast levels of the screen.
Use the PAGE button to access the Satellite Page.
Press and release the ENTER button to display the Options Menu.
Press ENTER to display the Display Setup Page.
Press ENTER when the line below LIGHT TIMEOUT is highlighted.
Use the UP/DOWN buttons to select the desired length of time for the backlight timeout.
Press ENTER to select the highlighted length of time.
Use the UP/DOWN buttons to select the slider bar below the CONTRAST field.
Press the Enter button to select the slider bar to adjust the contrast.
Use the UP/DOWN buttons to adjust the contrast.
Press ENTER when done.
Turning the Backlight On and Off
Press the POWER button to turn the backlight On.
Press POWER again to turn the backlight Off.
If no other button is pressed, the backlight turns off automatically after 30 seconds or whatever time you have set through the Display Setup Page, which can be accessed from the Main Menu or the Satellite Page.
