Limitations in Pairing a PT Collar to a Delta XC Model Handheld
Garmin produces several models of dog training systems such as the Delta® XC series and Pro Series. It is possible to pair a Pro (PT) model dog device to a Delta XC model handheld, however, some of the collar and training functions will only work with the original model handheld with which it was intended to be used.
Limitations
If you pair a PT 10 collar to a Delta Sport XC model, you will not be able to use the handheld remote enabled BarkLimiter™ feature or the Beacon Lights. There can also be minor variances in the electronic stimulation intensity levels from handheld to handheld.
Features that Work the Same
Warning tone and vibration will work the same for any handheld and collar combination. In essence, the electronic stimulation, warning tone, and vibration can still be used; and manually enabled BarkLimiter control is still available as well.
