What is the Kill Switch Feature of a Garmin Watch
Some Garmin watches offers a hot key option named Kill Switch. The Kill Switch allows you to reset your watch quickly, dumping any stored data and reverting the watch to factory settings.1 You may find this option useful if you work in a position where data saved on your watch could be considered sensitive.
NOTE: The Kill Switch is not set by default. This is because the Kill Switch will perform a reset of your watch, and should only be set to a hot key if your data could be compromised. We recommend setting the Kill Switch to a two button combination hot key so that it is not accidentally engaged.
Setting the Kill Switch Hot Key
  1. Hold UP/MENU.
  2. Select System.
  3. Select Hot Keys.
  4. Select the hot key you would like the Kill Switch set to.
  5. Select Kill Switch.
1 The Kill Switch will perform a full master reset of your watch. Any saved data, sensor or device pairings, custom settings, and device history will be deleted when using the Kill Switch.
2 When the Kill Switch is engaged a countdown timer will start, and the watch will power off and back on. It will then display an eraser icon for several minutes before returning to initial setup.
Related
