Sending a MapShare Link From an inReach SE(+)/Explorer(+)
Depending on which feature you have enabled on your account, a LiveTrack™ page link or a MapShare™ page link can be sent to friends and family directly from an inReach® device after tracking has been started so that they may follow your progress. If you are using MapShare and have set a password for your MapShare page, the password is included automatically when you use the share feature from the website, the device or the mobile app.
NOTE: Before attempting to send your MapShare link, MapShare should be enabled and configured in your inReach account. For assistance, see - Setting Up MapShare for an inReach SE®, inReach SE+, inReach Explorer®, or inReach Explorer+. For more details on LiveTrack, see - LiveTrack for inReach.
From the home screen, select Tracking.
Select Start or Start Tracking.
Select Share.
Select the To field to type in your recipient(s), or use
or
to choose from your saved contacts.
Select the Message field to customize your message.
A default message of I'm starting my trip. Follow along here! will be pre-filled. You can edit or add to this message, if desired. A link to either your LiveTrack page or your MapShare page will be included with the message.
Select Send or Send Message.
