Bluetooth Connected Alert on vivosport and vivomove HR
The Bluetooth Connected setting is available if you would like to know when your device gets disconnected and reconnected with the paired smartphone. By default the Bluetooth Connected alert is disabled. If you would like to enable this setting see the details below:
  1. Open the Garmin Connect app.
  2. Open the menu by selecting More (bottom right.)
  3. Select Garmin Devices.
  4. Select your device.
  5. Select Device Settings.
  6. Select Notifications & Alerts.
  7. Toggle Bluetooth Connection on.
Related
