Changing the Vehicle Type or Usage Mode on a dēzl™ 760
The vehicle type determines how the device will calculate routes. For additional details on how each of these vehicle types works, view the list at the bottom of this article.
To change the vehicle type:
- Touch the vehicle type icon at the top of the main menu
- Touch the desired vehicle type
- Touch Save to save the change
Repeat the steps above to change the vehicle type again.
Vehicle types and usage modes:
- Automobile: This is the most-used setting that will give you turn by turn directions based on mapping and road information.
- Truck: This setting will provide turn-by-turn directions using major roads. This setting will also attempt to keep you off parkways or small streets where it would be hard to turn around with a larger vehicle.
- Camper/RV: This setting will provide turn-by-turn directions using major roads. This setting will also attempt to keep you off of parkways or small streets where it would be difficult to turn around with a larger vehicle.
