Discontinued Garmin Marine Chartplotters Map Compatibility
Some discontinued chartplotters still have compatibility with the newer BlueChart® g3 mapping. As the maps will continue to increase in size, devices currently compatible in future versions may become incompatible. The tables below will help determine what is available. The US All and Canadian West Coast chart exceeds the size limit for many older units. If the table lists regular or small regions, it would need to be smaller. Those maps are going to be a vision cards.
Device series incompatible with Large and Extra Large BlueChart g3, and/or no longer compatible with current LakeVu™ mapping products
The last version of BlueChart or LakeVu™ G2 charts was version 2018.52 which are no longer available through Garmin. The following devices were designed for use with BlueChart G2 and LakeVu G2 chart products and have limited and or no compatibility at all with some G3 chart products.
  • GPSMAP® 4x0/s
  • GPSMAP® 4x1/s
  • GPSMAP® 4x6/s
  • GPSMAP® 5x0/s
  • GPSMAP® 5x1/s
  • GPSMAP® 5x5/s
  • GPSMAP® 5x6/s
  • GPSMAP® 5x7*
  • GPSMAP® 6x0
  • GPSMAP® 7x0/s
  • GPSMAP® 7x1**
  • GPSMAP® 8x0*
  • GPSMAP® 10x0*
  • GPSMAP® 4xxx
  • GPSMAP® 5xxx
  • GPSMAP® 6xxx
  • GPSMAP® 70xx
  • GPSMAP® 72xx
* These GPSMAP units listed above are partially compatible with BlueChart g3 Vision cards but must be small or regular region-sized maps. High-Resolution Shading and Raster charts are not supported on the indicated units. The designation will have an S or R at the end of the chart number, for example, BlueChart g3 Vision | VUS011R.
** The GPSMAP 7x1 series is not compatible with BlueChart g3 Vision charts.
L Chart: A "Large" (L) chart is designated with a "L" at the end of the chart number
Example: U.S., Boston, MA to Norfolk, VA Coastal Charts BlueChart g3 Vision VUS511L
The "L" at the end of VUS51L designates this particular chart as a Large chart
XL Chart: An "Extra Large " (X) chart is designated with an "X" at the end of the chart number
Example: Canada Coastal Charts BlueChart g3  HXCA600X
The "X" at the end of HXCA600X designates this particular chart as an Extra Large chart
Yes: Compatible
S: Supplemental Chart feature that is not available on built-in charts (See Notes)
No: Not compatible
* Raster charts can be viewed in the ActiveCaptain app
BlueChart g3 feature compatibility table
BlueChart g3
Chartplotter model
Basic chart detail
Auto Guidance
Depth Range Shading
1' Contours
Shallow Water Shading
Raster Charts*
GPSMAP® 80xx / GPSMAP® 82xx
Yes
Yes
S
S
Yes
Yes
GPSMAP® 8500 Series
Yes
Yes
Yes
Yes
Yes
No
GPSMAP® 5x7* / GPSMAP® 7x1* / GPSMAP® 8x0* / GPSMAP® 10x0*
Yes
Yes
No
Yes
Yes
No
GPSMAP® 4xxx* / GPSMAP® 5xxx* / GPSMAP® 6xxx* / GPSMAP® 70xx* / GPSMAP® 72xx*
Yes
No
No
No
Yes
No
GPSMAP® 7x0*
Yes
No
No
No
Yes
No
GPSMAP® 6x0*
Yes
No
No
No
Yes
No
GPSMAP® 4x0* / GPSMAP® 4x1* / GPSMAP® 4x6*
Yes
No
No
No
Yes
No
GPSMAP® 5x0* / GPSMAP® 5x1* / GPSMAP® 5x5* / GPSMAP® 5x6*
Yes
No
No
No
Yes
No
GPSMAP® 62s / GPSMAP® 62st / GPSMAP® 62sc
Yes
No
No
No
No
No
ECHOMAP™ CHIRP / echoMAP (non-chirp)
Yes
Yes
Yes
Yes
Yes
No
BlueChart g3 Vision feature compatibility table
BlueChart g3 Vision
ChartplotterBlue Chart g3 FeaturesAuto GuidanceHigh Resolution Shaded Relief3D Chart ViewsSatellite ImageryAerial PhotosRaster Charts* (view on chartplotter)
GPSMAP® 80xx / GPSMAP® 82xx / GPSMAP® 8500 seriesYesYesYesYesYesYes
GPSMAP® 5x7 / GPSMAP® 8x0 / GPSMAP® 10x0 (regular or small regions)YesYesNo YesYesYesNo
GPSMAP® 4xxx / GPSMAP® 5xxx / GPSMAP® 6xxx / GPSMAP® 7xxx (regular or small regions)YesYesNo YesYesYesNo
GPSMAP® 4x0 / GPSMAP® 5x0 / GPSMAP® 6x0 / GPSMAP® 7x0 (regular or small regions)YesYesNo YesYesYesNo
GPSMAP® 4x1 / GPSMAP® 5x1 /x (regular or small regions)YesYesNo YesYesYesNo
GPSMAP® 4x6 / GPSMAP® 5x5 / GPSMAP® 5x6 (regular or small regions)YesYesNo YesYesYesNo
ECHOMAP™ CHIRP / echoMAP (non-chirp)YesYesNoYesYesYes
No
LakeVu g3 feature compatibility table
Basic chart detail: includes shoreline detail, spot depths, markers, marine services, tides and currents where applicable
Yes: Compatible
No: Not compatible
LakeVu g3
Chartplotter model
Basic chart detail
Auto Guidance
1' Contours
Depth Range Shading
GPSMAP® 80xx / GPSMAP® 82xx / GPSMAP® 85xx series
Yes
Yes
Yes
Yes
Yes
ECHOMAP™ CHIRP / echoMAP™ (non-chirp)
Yes
Yes
Yes
Yes
Yes
LakeVu g3 Ultra feature compatibility table
LakeVu g3 Ultra
Chartplotter
LakeVu g3 Features included
Auto Guidance
High-Resolution Shaded Relief
3D Chart Views
Dynamic Lake Level
Satellite Imagery
Aerial Photos
Surface and
Side Scan Photos
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
Related
