ecoRoute HD Cable Not Pairing with a Garmin Device
There may be times when the ecoRoute HD cable will not pair with your device. Correcting this issue can be accomplished by following the steps below:
  1. Update the device using Garmin Express
  2. Enable the device's Bluetooth
  3. Attempt to pair the HD accessory to your device
  4. Reset both the ecoRoute HD accessory and the device if problems persist after the above steps
Detailed instructions for each of the above steps can be found below.
To Enable the Bluetooth after Updating Device Software:
  1. Touch Tools
    • Skip this step on some devices
  2. Touch Settings
  3. Touch Bluetooth
  4. Touch the blue box under or next to Bluetooth
    • Some devices may require you to touch the box next to Enable Bluetooth to insert a check mark.
  5. Touch Enabled
  6. Touch OK
The Bluetooth on your device is now enabled.
To Pair the Device with the ecoRoute HD Accessory Cable:
Review the related content for step-by-step instructions on this step.
If the device is still not pairing with the ecoRoute HD cable, reset the ecoRoute HD accessory by pressing the Reset button on the cable.
Note: The dezl and Camper/RV series must be in automobile mode to use ecoRoute.
Related
