MODE Pin Does Not Go Below a Certain Voltage Level
If you experience a problem with the MODE pin not going below a certain level and causing a problem with distance readings in this mode we recommend replacing the 1k pull down resistor with up to 330 ohms.
Notice: The circuit will be required to sink to 10 mA with this configuration
