Requesting Weather Forecasts With an inReach Messenger Plus
With up-to-date software, the inReach® Messenger Plus satellite communicator automatically provide both premium/extended forecast data and marine forecast data, if available, whenever a new forecast is requested. This article will cover how to request weather forecasts from the inReach device only. For information on requesting weather using the Garmin Messenger™ app, see - Requesting Weather Forecasts With the Garmin Messenger App.
Important Notes
Updating a forecast may incur data charges or additional usage charges.
For more information about Basic, Extended, and Marine weather, see - Frequently Asked Questions on Weather for inReach.
A marine forecast will be included for locations on an ocean or other large body of water, if available. If you are unable to get a marine forecast, select a location further from shore.
Requesting a Weather Forecast
From the home screen, press
or
to scroll through the main menu.
Select WEATHER
Press OK
Select Update Forecast.
NOTE: A marine forecast will also be included automatically, if available.
Press OK to get new forecast, then select Continue.
The inReach device will then send a request for the forecast. It can take several minutes to receive the weather forecast data. Ensure you have a clear view of the sky. Once the inReach receives the forecast, you can view the forecast at any time until all the information in the forecast has expired. If available, marine forecast data can be viewed by pressing OK and selecting View Marine. The forecast can also be updated at any time.
Changing the Weather Location
NOTE: These steps will only work if the Garmin Messenger app has already been used to add other weather locations. For more details, see - Requesting Weather Forecasts With the Garmin Messenger App .
or
Select WEATHER
Press OK.
Select Change Location.
Select an option:
My Location: Sets the forecast to your current location.
Select one of the weather locations that you have used previously (if applicable).
Land Forecast | Land Forecast Detail |
Marine Forecast | Marine Forecast Detail |
The following are examples of included data and icons when a weather forecast is requested.
Percipitation Percentage
Temperature High and Low
Wind Speed and Direction
Wave Height (Marine Forecasts Only)
For examples of other weather related icons, see - Frequently Asked Questions on Weather for inReach.
