Rally Series Power Meter Cleat Options
Garmin offers three cleat options for the Rally™ series power meter system. Select a link below for replacement cleat purchase and availability on Garmin.com.
NOTE: On RK and RS cleats, the rubber center cap can be used to adjust the feel of the cleat float1 and provides reduced friction when removed. It also acts as a protective cover for shoes with mounting hardware for the LOOK Memory Tab on RK cleats.
Included in the Box of All Rally™ RS Power Meter Systems
Red Cleats - 4.5° float1
Included in the Box of All Rally™ RK Power Meter Systems
Red Cleats - 6° float1
Included in the Box of All Rally™ XC Power Meter Systems
1 Pedal float is the amount by which the foot can move (twist) before releasing from the pedal. The amount of float is measured in degrees.
