Transferring BaseCamp Data to New Database or Computer on Windows
When creating a new database in BaseCamp™ software, the new database will be empty at first and will not have any data from the default database. Using cloud storage can keep your data backed up and accessible from different computers. The steps outlined in this are for Windows-based operating systems.
NOTE: Importing data from one database to another will import the content (waypoints, routes, tracks, etc.) The import process will not import the folders the content was originally organized in.
Creating a New Database:
  1. Select Edit on the Toolbar
  2. Select Options
    • Edit menu showing items that can be selected
  3. Select General
  4. Select small white plus on green background next to Default
  5. Create a name for a new database
    • Pop up windows showing both the browse option and new database
  6. Select Browse
  7. Select where the new database should be located
    • Select Make New Folder to add a folder in the desired location (ex, BaseCamp New Database within My Documents, as shown above)
  8. Select the OK box on both the Browse window and New Database window
  9. Use the drop-down to select Default
  10. Select OK
  11. Follow the steps below for exporting and importing data before using the new database
Exporting and Importing Using a Third-Party Cloud Service
This example uses Amazon Cloud, however, any cloud service, such as DropBox, Google Drive, or OneDrive should work.
Exporting Data from BaseCamp Software:
  1. Select My Collection from Library
  2. Select File from the Toolbar
  3. Select Export
    • File menu showing export is highlighted
  4. Select Export 'My Collection'...
  5. Find and open the folder created in #7 above.
  6. Click on Database
  7. Click on the version folder (ex. 4.7 which is a BaseCamp version)
  8. Change Save as type to: Garmin GPS Database Files (*.gdb)
  9. Select Alldata.gdb
    • Pop up window asking where to save file and confirming the save
  10. Select Save
  11. Select Yes when asked to replace it
Importing Data into the New Database:
  1. Select Edit from the toolbar
  2. Select Options
    • Edit menu showing options as highlighted
  3. Select General
  4. Select the name of the newly created database
    • Pop up window showing drop down to select database
BaseCamp software will now restart. Once restarted, BaseCamp software should load with all your data listed.
