Setting Up the Garmin eLog
You must set up and pair your Garmin eLog ELD adapter with the Garmin eLog app in order to be in compliance with FMCSA ELD regulations.
Download and install the Garmin eLog app on your mobile device to begin. See below for instructions on installing the Garmin eLog app and pairing with your device.  Only one Garmin eLog ELD may be paired with Garmin eLog app at a time.
iOS
This Video is a Quick and Easy way to Learn about Pairing your Device with the Garmin eLog app.
1. Open the Apple App Store application  on the iPhone or iPad
2. Search for "Garmin eLog"
3. Touch Get and download the app
4. Touch Open
5. Review and agree to the Terms and Conditions
6. Touch Continue
7. Touch Next
    • Touch Always Allow when prompted to allow the Garmin eLog access to your location
NOTE: Make sure the vehicle is turned OFF to proceed
8. Firmly plug the adapter into the vehicle's diagnostic port
NOTE: The standard connection is 9-pin. It may be necessary to use the included adapter for a 6-pin port or a third party adapter for a 16-pin port. OBD-II protocol is NOT supported at this time.
9. Turn the locking ring clockwise to secure it in place
10. Turn on the vehicle
11. Push the button on the Garmin eLog ELD adapter for one second until you hear a tone
12. Touch "View nearby adapters"
13. Select the Garmin eLog from the list of available devices
14. Confirm the Vehicle Information. Some vehicles will automatically communicate the VIN and CMV ID. Manually enter the requested information if prompted.
a. Enter the full 17 digit VIN
b. The CMV ID should be known to you or your company. If you do not have a CMV ID, enter any alphanumeric code in this field.
15. Touch Confirm
16. Touch Go to Next Step
17. Create an Administrator Profile
NOTE: The app requires a separate Administrator Profile and Driver profile, but cannot use the exact same name for both
18. Touch Save and Finish
19. The Setup Complete message will display. Touch Add Driver to continue.
20. Enter in driver information, exemption information, carrier information, 24-Hour starting period, weekly rule set, and load-type rule set
NOTE: The 24-Hour Starting Period should be set before you expect to begin your day. This should be set by your motor carrier. You can set it to 00:00:00 (Midnight) if you don't have a normal schedule.
21. Choose whether to allow Personal Conveyance and Yard Move options
22. Touch Save
23. Login to the driver profile to begin using the Garmin eLog
Android
1. Open the Google Play Store on the smartphone or tablet
3. Select Garmin eLog
4. Touch Install
5. If prompted for access to Location, Files, and Bluetooth, touch Accept.
NOTE: The eLog will not be compliant with FMCSA regulations if you do not allow access.
6. The app will download and install. Touch Open.
7. Place a checkmark in the box to indicate you have read and agree to the Garmin terms of use
8. Touch Continue
9. Touch Next
10. Turn off the vehicle
11. Firmly plug the adapter into the vehicle's diagnostic port
12. Turn the locking ring clockwise to secure it in place. The adapter will briefly illuminate and play a tone when plugged in.
13. Turn on the vehicle
14. Push the button on the Garmin eLog ELD adapter for one second until you hear a tone. This places the ELD in Bluetooth pairing mode.
15. Touch Next on the Garmin eLog app
16. Touch OK to pair
17. The ELD adapter will pair and display the message "Adapter Connected"
18. Touch Go To Next Step
19. Confirm the Vehicle Information. Some vehicles will automatically communicate the VIN and CMV ID. Manually enter the requested information if prompted.
20. Touch Confirm
21. Touch Go To Next Step
22. Create the Administrator Profile
NOTE: The app requires a separate Administrator Profile and Driver profile, but cannot use the exact same name for both.
23. Touch Save and Finish
24. The Setup Complete message will display. Touch Add Driver to continue.
25. Enter in driver information, exemption information, carrier information, 24-Hour starting period, weekly rule set, and load-type rule set.
26. Choose whether to allow Personal Conveyance and Yard Move options
27. Touch Save
28. Login to the driver profile to begin using the Garmin eLog
dēzl™ 780/dēzlCam™ 785
1. Touch the eLog app from the home screen
2. Place a checkmark in the box to indicate you have read and agree to the Garmin terms of use
3. Touch Continue
4. Turn off the vehicle
5. Firmly plug the adapter into the vehicle's diagnostic port
6. Turn the locking ring clockwise to secure it in place. The adapter will briefly illuminate and play a tone when plugged in.
7. Turn on the vehicle
8. Push the button on the Garmin eLog ELD adapter for one second until you hear a tone. This places the ELD in Bluetooth pairing mode.
9. Touch Next in the Garmin eLog app
10. The ELD adapter will pair and display the message "Adapter Connected"
11. Confirm the Vehicle Information. Some vehicles will automatically communicate the VIN and CMV ID. Manually enter the requested information if prompted.
12. Touch Confirm
13. Touch Go To Next Step
14. Create the Administrator Profile and touch Save and Finish
15. The Setup Complete message will display. Touch Add Driver to continue.
16. Enter in driver information, exemption information, carrier information, 24-Hour starting period, weekly rule set, and load-type rule set.
17. Choose whether to allow Personal Conveyance and Yard Move options
18. Touch Save
19. Login to the driver profile to begin using the Garmin eLog
dēzl™ OTR800/dēzl™ OTR1000
1. Touch the Garmin eLog app from the home screen
3. Touch Continue
10. Touch Next
11. The ELD adapter will pair and display the message "Adapter Connected"
12. Confirm the Vehicle Information. Some vehicles will automatically communicate the VIN and CMV ID. Manually enter the requested information if prompted.
13. Touch Confirm
14. Touch Go To Next Step
15. Create the Administrator Profile and touch Save and Finish
16. The Setup Complete message will display. Touch Add Driver to continue.
17. Enter in driver information, exemption information, carrier information, 24-Hour starting period, weekly rule set, and load-type rule set.
18. Choose whether to allow Personal Conveyance and Yard Move options
19. Touch Save
20. Login to the driver profile to begin using the Garmin eLog
dēzl™ OTR810/dēzl™ OTR1010
1. Touch Apps
2. Touch eLog
3. Touch Continue
10. Touch Next
13. Touch Confirm
19. Touch Save
See the Links Below for Additional Information.
