Displaying Collection Data on the Map of the Garmin Explore App
You can control what data appears on the map of your Garmin Explore app by toggling data collections on or off with the steps below. Data includes waypoints, tracks, routes, and activities.
This is helpful to declutter your map, show where you have traveled before when re-visiting the same area, see only the pre-planned data you need for your current trip, etc.
Toggling Collection Data
  1. Open the Garmin Explore app.
  2. Select Unfolded Map Symbol Map.
  3. Select Three Stacked Layers.
  4. Select Book With Location Pin Collections.
  5. Touch on the desired collections to show or hide them on the map.
    Map Collection Toggles
    • Solid Eye Ball = Shown on map.
    • Eye Ball With a Slash Through It = Hidden on map.
      • You can also select Hide All to hide data from every collection, or Show All to show data from every collection.
  6. Touch X to return to the previous screen.
  7. Touch X to return to the map.
Your map should now only display the data from the enabled Collections.
Related
